45hp with mid mower options?
   / 45hp with mid mower options? #1
Muleman4570
Cub Cadet 7275
Greetings,
I currently have a Cub 7275 with loader and mid mower and am looking to go up in HP(Cub is 27hp) and slightly newer. The Cub I have owned for almost 20 years with no real issues. I can't justify a new rig nor do I want Tier 4 anything on the place.
I am looking for options for 45+- hp tractor with loader and has mid mower capability. No cab needed as I have ASV track loader with cab/heat for snow moving. The mower needs to go on and off relatively easy. I tried rear finish mower but prefer the mid-mount mower with my acreage.
My budget is around 25K.
So far I found JD 3720 with Auto Connect mid mower decks as one possibility? I am open to other brands just can't seem to find much else for options with my criteria.
Any thoughts of other brands or models is appreciated.
PJ
   / 45hp with mid mower options? #2
you are going to have trouble finding that large a tractor with a mid mount mower. Have you looked at flail mowers for rear mount mowers. they stick out much less from the rear of the tractor, if that was what was bothering you about a rear finish mower.
   / 45hp with mid mower options? #3
I think the New Holland Workmasters can do mid mowers up to 45HP.
   / 45hp with mid mower options? #4
Several brands do not have regen if that is what you are concerned about ,Otherwise you will have to look at older machines and will be limited looking for a mmm in that size.
   / 45hp with mid mower options? #5
Tractorhouse has several jd 3720 with mmm listed. they are 44 hp
1997 John Deere 8100 MFWD Tractor (A52748)
1997 John Deere...
FIRESTONE 20.8R42 REAR TIRES WITH WHEELS (WHEELS FITS GENESIS TG-T8000 TRACTORS) (A52748)
FIRESTONE 20.8R42...
2002 International 9200i Truck (A52748)
2002 International...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
