455 Lawn Tractor glow plug
   / 455 Lawn Tractor glow plug #1
jcalla
Triangle, VA
1999 455 (2100 hrs plus) lawn tractor not starting (in cold weather) like it should. I'm thinking glow plugs maybe dirty or worn out. Does anybody know if they loose their heat value over time? Could I just take them out and clean them or should I replace them? Is it time to have the injector nozzles rebuilt?
JPC
   / 455 Lawn Tractor glow plug #2
I would put my money on glow plugs. They will burn out with time but you also want to make sure that you have 12 volt going to the plug first. If so the glow plug can be check using a ohm meter. Not familiar with the 455 but you may have to remove them for checking them.
   / 455 Lawn Tractor glow plug #3
They either work or not. Heating element doesn't get dirty like injector. Ohm meter will tell you if they are good, it will show a dead short, just like touching the leads together (0 ohms) if it is working. Injectors may need servicing but likely not the cause of starting. Even the dirtiest fouled injectors will usually start but not produce full power and or lots of black smoke (dirty air cleaner will do the same thing)
   / 455 Lawn Tractor glow plug #4
replace the glowplugs. I have a little perkins 2 cyl. on a genset and if I get a 1000-1500 hrs out of them i'm lucky
2012 FORD F-450 XL SUPER DUTY BUCKET TRUCK (A51406)
2012 FORD F-450 XL...
2014 FREIGHTLINER CASCADIA MID ROOF SLEEPER (A54607)
2014 FREIGHTLINER...
PALLET OF 15-BLACK GROUND PROTECTION MATS. 4FT X 8FT (A53843)
PALLET OF 15-BLACK...
2015 MACK CXU613 MID-ROOF SLEEPER (A53843)
2015 MACK CXU613...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
