455 AWS Front pivot bushing
/ 455 AWS Front pivot bushing #1
theedudenator
There is a pin and bushing in the front center of the tractor.
This looks like the main part that the steering wheel attaches to.
When I turn the steering this part has slop/moves around.
JDparts is showing dual bushings.
Anyone changed these? Is it a difficult job?
/ 455 AWS Front pivot bushing #2
Hard to say about the bushings, but there are bearings that I see in JD parts. that may need some replacement.
There is always some slop, but wondering if you are getting something worse?
I've had several of the AWS and not had any problems. A neighbor had a linkage break, so he said and had to replace it.
Item 12 on this image.
The tie rod ends, #13 were loose. Looks like the nuts are digging into the plate.
It is not shown but the center hole of item 12 has the hole for the cylinder.
This also has slop.
There is no bushings in this plate, I think there should have been....
John Deere - Parts Catalog
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
2021 Case IH 540 Steieger (A66285)
2021 Case IH 540...
2007 Ford F-450 Flatbed Truck, VIN # 1FDXF46P77EA72394 (A65563)
2007 Ford F-450...
INSPECTION (A65579)
INSPECTION (A65579)
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
