4530??
   / 4530?? #1
wedge40
Veteran Member
Looking at the new website. Looks like they changed the backhoe that comes with the 4530 to a smaller one. I was looking that this tractor because it was the smallest tractor with the largest backhoe. Use to be the 595 BH now it's the 485 BH.. There is a one ton difference in prying power between these two backhoes.
Wedge
   / 4530?? #2
It came with the 509 hoe built by bradco at one time. That's a very good machine.
   / 4530?? #3
I bet we can still order the 509E, but I am not certain. In theory, a 511 with the "E" kit would fit also. My only concern with the 4530 with a big hoe is if you are on hilly property, the dry disc brakes are challenged with a fully loaded (these things are heavy) TLB going down a steep hill. The 5530 uses wet brakes and also has a bigger front axle.
   / 4530??
Found the problem. The new website is pointing to the wrong spec sheet. If you look at spec sheet for 4530, it pulls the sheet for 4035.
Wedge
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
Xtreme XR1045 (A50120)
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2016 Ford Explorer...
