4530 having problems shifing into 3rd or 4th
/ 4530 having problems shifing into 3rd or 4th #1
TXAG
College Station, TX
Mahindra 4530
I recently purchased a 4530 and have about 15 hours on it now. I don't shift a lot between 1 - 4 but I was running around with a seed spreader and thought I would speed up a bit and tried to shift into 3rd. It would not shift into 3rd or 4th at all. It felt like I was up against a sponge but it would not engage. I shifted everything else into neutral and still it would not shift into 3rd or 4th. I continued in 2nd high and finished the job although it was a bit faster than I had planned. When I got back to the parking spot, I tried it again and it shifted just fine into 3rd of 4th. Any ideas on what could be causing this? It will be a pain to run it back to the dealer because I don't have a trailer big enough and have to depend on a buddy to haul it around. 4wd was not engaged at all during this.
/ 4530 having problems shifing into 3rd or 4th #2
I don't think you have a big problem but I am no mechanic. I think everything is still new and needs to be broken in. Use it with a smile on your face. I just looked at the Mahindra site, that thing looks like a beast.
/ 4530 having problems shifing into 3rd or 4th #3
I have a 4530 that had the same problem. I am a car mechanic that has worked on the old floor shift cars.(Hurst shifters and stock) This tractor has to be adjusted on the shift linkage the same way. When I took my floor board up two hydraulic lines for the FEL was rubbing on the shift arms also. My dealer said it shifted OK. My wife could not shift it. Now it works.
/ 4530 having problems shifing into 3rd or 4th #4
I also have a new 4530 with about 15 hours on it and I am having the same problem. I actually posted about this a couple of weeks ago but didn't get any replies. I find mine will not go into third or fourth while moving. If I am in 2nd and try to shift into third on the run, it feels just as you explained it - spongy. I have to bring the tractor to a stop and cycle through all the gears while going on and off the clutch. It will finally mesh and go, but is a real pain. I also have problems sometimes going into 2nd. It pops in but when I let out on the clutch the gears start grinding like it is not in full synch. I have to cycle again and finally it gets in. I haven't talked to my dealer yet about this, but he did tell me when I bought it that the gears feel spongy and is mostly only on the 4530's. He didn't know of any fix but said if it gets to be a real problem to bring it in and he would call in the reps.
Keep us posted and let us know if you find out anything. Also, we should stay in touch through pm's so we can track each others problems. I have asked a couple of other 4530 owners to do the same. Maybe we can help each other on like problems.
/ 4530 having problems shifing into 3rd or 4th #6
If you are experiencing this problem, please send an email to marketing@mahindrausa.com, along with your name, dealer where purchased and serial number. I will forward your email to our tech service department to respond.
/ 4530 having problems shifing into 3rd or 4th #7
It will shift slick if you spend about 2-3 hours getting the linkage correct. The shop foreman at my dealer said he had never worked on a shifter like this. The reason for the time is that the shift adjustment linkage is hard to get to and it has to be correct.
/ 4530 having problems shifing into 3rd or 4th #8
Musa, I sent you an email. Thanks.
Is there any known fix to this or can the linkage be beefed up. It does feel weak, almost as if it wouldn't take much to bend or break it. I am gentle with mine and try to never force it, but I have two John Deere Gators that also have an issue with the linkage and they have broken with little or no pressure.
/ 4530 having problems shifing into 3rd or 4th #9
Just wondering
I don't know the specific tractor nor the specs but,
Could it be that 3rd and 4th are non syncro gears? but 1 and 2 syncro?
On my little MT180D all gears are non syncro, so I am used to coming to a complete stop before shifting. Even then higher gears, due to ratios, are always a little trickier to engage.
I sometimes have to slip a bit the clutch to engage (align) them.
I think it is all synchromesh since the specs list it as:
TRANSMISSION
Type: Forward-Reverse Synchro-Shuttle with full synchromesh
Number of Speeds: 8 forward, 8 reverse
/ 4530 having problems shifing into 3rd or 4th #11
</font><font color="blue" class="small">( Musa, I sent you an email. Thanks.
Is there any known fix to this or can the linkage be beefed up. It does feel weak, almost as if it wouldn't take much to bend or break it. I am gentle with mine and try to never force it, but I have two John Deere Gators that also have an issue with the linkage and they have broken with little or no pressure. )</font>
Have you been contacted by our service department yet?
/ 4530 having problems shifing into 3rd or 4th #12
Not yet. I will pm you with my phone number to forward to them.
OK finally remembered to take a pen with me and write down the serial number, Email is on its way.
/ 4530 having problems shifing into 3rd or 4th #14
I just got a call from my dealer. They are sending a mechanic out today to fix the linkage on the tractor. All it took was one phone call to the salesman that sold me the tractor and he done the rest. No complaints, no arguments. All he told me was the service manager would be contacting me. Next thing I knew they are coming out to fix it.
I will update as to what he had to do and how it works after I talk to him and get home this evening to try it out.
musa_marketing,
Thanks for your support on this. It wasn't even a big concern to me that I was having this probem, but you wouldn't leave it alone until the problem was corrected. Hats off to you, Mahindra, and Singleton Tractor in Franklinton, LA. I'm pleased to do business with people with such commitment as you.
/ 4530 having problems shifing into 3rd or 4th #15
I second that.
Singleton Sales & Service has been very good to me. They are the friendliest tractor dealership I have ever been to......I like how you walk in the door and smell/see a fresh pot of coffee... /forums/images/graemlins/wink.gif.....I especially like Mike and Buddy.
Travis
/ 4530 having problems shifing into 3rd or 4th #16
Mr. Mike called me yesterday evening to discuss the problem with my tractor. He said the mechanic did not find anything. The very first models that moved the shifter to the side had trouble with the linkage, but since mine is only a couple of months old it already had the upgrade. He explained that the gears had to stop in order to mesh. This means pushing the clutch in and giving it time to slow down then try to shift. Also, when shifting from 2 to 3 make sure not to use a z-pattern but rather go to neutral then across then into 3rd. He said it will probably just take time to get used to the way it shifts but should be okay. He insisted if I have any more problems to let him know. In short, the extra linkage it took to move the shifter to the side makes it harder to shift and more apt to bend if forced.
I apologized for the trouble and offered to give him money for fuel for the wasted trip, but he wouldn't hear of it. These are truly great people to deal with.
32" Smooth Lip Mini Bucket  (A62679)
32" Smooth Lip...
John Deere 6000-Series Tractor Lift Arms (A65640)
John Deere...
(2) Firestone Tires (A65640)
(2) Firestone...
2012 Jeep Compass (A64194)
2012 Jeep Compass...
JOHN DEERE 925F - 25' GRAIN HEAD (A64277)
JOHN DEERE 925F -...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
