4520R Hydraulic Screen
/ 4520R Hydraulic Screen #1
JonnyRed
North Georgia
5835R Branson
Getting ready to change out hydraulic fluid and filter.
Anyone familiar with whether or not their is a screen that needs to be flushed out and the location/process for accessing it?
Owners manual does not address.
/ 4520R Hydraulic Screen #2
They refer the screen as "strainer" on the Service Manual. The hydraulic filter runs on the intake side of the pumps, if you follow the big pipe that goes to the transmission case, there should be like a triangular flange bolted to the case. If you want to really clean it, you might have to remove the big pipe and the flange.
Here is a pic from the manual. I marked the pipe that needs to be removed in order to access the screen.
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
GROVE RT 63S HEAVY DUTY HYDRAULIC CRANE (A60736)
GROVE RT 63S HEAVY...
Yanmar YT359 (A53317)
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
40' High Cube Multi Door Shipping Container (A60463)
40' High Cube...
