4520R Fuel Filter
/ 4520R Fuel Filter #1
JonnyRed
North Georgia
5835R Branson
Tractor has 100 hours on it (2 years old) and I am wondering if there is any action I need to take with emptying/cleaning the fuel filter.
Can someone walk me through the correct process? Main concern is getting air in the system and having an issue afterwards.
Might be overthinking it but thought I would ask.
/ 4520R Fuel Filter #2
There's usually a bleed screw on the top of the filter housing. You can remove the filter or dump the bowl out to inspect, then run the lift pump with the bleed screw open until the air is bled out of the filter housing. You don't want to run the engine until the air is bled out as that will suck air into the injectors. On my 3725 there's a manual pump on the filter to help bleed the air but I think the 20 series has a different filter setup.
There should be something on this in the owner's manual or shop manual.
/ 4520R Fuel Filter #3
Here is a link for the service manual for the 20 Series. I downloaded and saved it while I was looking for the manuals for the F series ( 15 series) for my tractor. At the time I thought I would save as many manuals as I could so if they remove them from the Internet, it could still be available. Ended up happening exactly like I thought.
Dropbox - Branson 20 series service manual.pdf
/ 4520R Fuel Filter #4
The 10 and20 series have the same manual. Here are Wix filters that should work.
Wix filter 51334 is the filter for oil
Wix filter 51202 for the hydraulics.
Air filter Wix 46438.
Fuel filter Wix 33263
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
KJ K2010 20'Lx10'Wx8'H Chicken Coop (A60463)
KJ K2010...
2012 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2012 TROXELL...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
