4520 with BB42
/ 4520 with BB42 #1
Honey Dealer
Saskatchewan
I Know that a 4520 has the hp to work a Frontier BB42, but will it ultimately have enough traction to do justice?
Will R4's do the job or are R1's more ideal for moving and tilling dirt.?
I am considering the 84" high back model.
/ 4520 with BB42 #2
I would think it depends on the soil in your locale. In 4x4 I don't have much problem with wheel slip and have about 1100 lbs of weights for ballast. If you have a fel and fluid filled tires you should be in good shape. In my area with rocky sandy loam I don't have traction problems nearly as much as when I lived in areas with lots of wet clay soil. I will usually do most dirt work when the ground is firm and dry rather than wet and muddy. I have the Frontier bb1284 which is similar to the bb42 series.
/ 4520 with BB42
You run loaded tires and four wheel weights?
/ 4520 with BB42 #4
For what it's worth if you have a FEL on a 4520 the book calls for filled tires and wheel weights and the ballast box.
I run a 7ft three way blade behind my 4520 with filled tires and sometimes the weights. No issues with the R4's. Unless it gets real sloppy then I add skidder chains to the rear tires.
CT
/ 4520 with BB42
jenkinsph said:
Nothing in the tires but three 110lb weights each rear wheel and six 70lb front weights.
Do you think R1's would make a noticeable difference for grading and tilling traction?
/ 4520 with BB42 #7
I would go with R1 tires if the conditions are likely to be wet or slightly muddy. The R1 tires are better for traction in snow too.
I haven't had any problems using R4 tires in my locale and prefer them as I have to work in and off of lawn areas. In the last seven years of use on my 110tlb and three years on the 4520 I can't recall a time when I had excessive wheel spin.
I have been using tractors for over 40 years and one of the most important things I learned is to do the grading and tilling when the conditions are most suitable. I don't move or use my tractors when it is too wet or sloppy, this just makes a bigger mess. If you pick the right time to do your grading and tilling either type tires will work well.
John Deere Pallet Forks (A66285)
John Deere Pallet...
2013 INTERNATIONAL DURASTAR 4400 FORESTRY BKT TRK (A63276)
2013 INTERNATIONAL...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
New Quick Attach Hay Spear (A65579)
New Quick Attach...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
2014 Nissan Sentra Sedan (A64557)
2014 Nissan Sentra...
