Tractor Sizing 4520 width
/ 4520 width #1
Honey Dealer
Saskatchewan
Can anyone tell me the width of a 4520 with R1 and R4 tires? Just trying to decide what width of box blade and tiller to purchase.
/ 4520 width #2
A 4520 is six ft wide more or less. For this tractor I have a 673 tiller which just barely covers the tracks, works great but if I did it over I would go with the 681 which is a little wider (80 inches IIRC).
I use an 84" boxblade which works out very well.
/ 4520 width #4
Below are the overall widths for the tires from the Operators Manual. Minimum size is when the rims are connected to the wheel hub the normal/standard way. The maximum size is when the rims are reversed and connect to the wheel hub. My 4520 has the R3s bolted on the normal way and the rears do measure ~73" to 74" wide.
Dimensions
Wheelbase 1.8 m (71.5 in.)
Overall Length w/ 3-Point Hitch 3.3 m (128.2 in.)
Overall Width w/ R1 Tires (Minimum) 1.7 m (65.6 in.)
Overall Width w/ R1 Tires (Maximum) 2.3 m (89.1 in.)
Overall Width w/ R3 Tires (Minimum) 1.9 m (74 in.)
Overall Width w/ R3 Tires (Maximum) 2.2 m (86.6 in.)
Overall Width w/ R4 Tires (Minimum) 1.7 m (68.4 in.)
Overall Width w/ R4 Tires (Maximum) 2.3 m (91.9 in.)
Overall Width w/ Golf Tires (Minimum) 2.1 m (81.4 in.)
Overall Width w/ Golf Tires (Maximum) 2.2 m (86.6 in.)
/ 4520 width #5
Be aware that you may not want the R4's in the min. width configuation. It puts the tires about 3/4" from the fenders on the inside. We moved ours out to the first wider setting.....much better.
/ 4520 width
I have decided to go with R1 tires and 7 foot implements.
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59912)
2019 ISUZU NPR 4X2...
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
2014 Sullair 185DPQ 100psi Towable Air Compressor (A61572)
2014 Sullair...
