4520 Rear Electrical Connections
   / 4520 Rear Electrical Connections #1
nebo
John Deere 4520
I recently bought a used 2012 open station 4520 and found several connectors on the back. I don't have a relationship with a dealer to ask him about these, just wondering if anyone can lend some info what these might be for and what powers them. Mainly inquiring because I eventually want to add the front and rear lighting kit on the ROPS and I assume these might be dedicated for that purpose. They have tags on them but have worn off before I acquired the machine.
Picture #1 5414.jpeg is under the seat
Picture #2 5417.jpeg is next to right fender behind seat
Picture #3 5418.jpeg is under seat to the left from behind
   / 4520 Rear Electrical Connections #2
Deere is pretty good about making things plug and play, light extra lighting for cuts. Really what you need to identify what is what is a multimeter/testlight, tech manual, or instructions from the oem kits to identify what is what. I believe # 2 is for lighting can't say for the other two they could be lighting, could be related to the cruise upgrade or something along those lines.
Thanks for the advice and good call on maybe the cruise upgrade reasoning....and I do plan to dive in deeper with my multi-meter. Haven't really found much info online so thought I would see if anyone had quick and dirty explanation before I spend a lot of time in maintenance and operation tech manuals.
   / 4520 Rear Electrical Connections #4
nebo
The service tech manual will give you the circuit diagrams, which along with the multi-meter will help you pinpoint and identify the connectors.
Hope you report back with your findings and light results.
nebo
That will definitely be my next steps. Thank you very much!
   / 4520 Rear Electrical Connections #6
One might be for a backup alarm?
RYOBI EASY START INVERTER GENERATOR (A51248)
RYOBI EASY START...
NAPA 80 GALLON ELECTRIC AIR COMPRESSOR (A51248)
NAPA 80 GALLON...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
2000 GENIE S-60 MANLIFT (A51246)
2000 GENIE S-60...
2021 BOBCAT T66 R-SERIES SKID STEER (A51246)
2021 BOBCAT T66...
