4520 mfwd is a pain ti engage/disengage
   / 4520 mfwd is a pain ti engage/disengage #1
yukonhunter
leroy ny
John deere 5100m, mf1643 cab and kubota bx2370woods bb720x land pride disc and reverse tiller
Is there a special trick to it...it says just lift up and down , but seems very hard to do so????
   / 4520 mfwd is a pain ti engage/disengage #2
It helps if you move a little bit. Engaging is usually pretty trouble free, disengaging some times I back up a little or turn the wheels left and right. What kind of trouble are you having?
I have never noticed it being any worse than anything other 4WD vehicle.
   / 4520 mfwd is a pain ti engage/disengage #3
It is brand new give it some time to loosen up and as Arlen mentions a slight movement will help. This is true for the range selector too.
   / 4520 mfwd is a pain ti engage/disengage #4
This on a 3320, so yours may be different. I let off on the eHydro pedal, make sure the front wheels are pointing straight - engage or disengage. Works while still moving, but have only tried in maybe 1-3 mph range - not fast.
   / 4520 mfwd is a pain ti engage/disengage #5
arlen is spot on. as you use it more it will loosen up
Thx guys
   / 4520 mfwd is a pain ti engage/disengage #7
It works much better if the tractor is not on a hard surface - blacktop or concrete, otherwise there can be a tendency to bind up.
   / 4520 mfwd is a pain ti engage/disengage #8
If It does bind up, I like to pick the front wheels off the ground with the loader. Then it will slide in and out easily.
   / 4520 mfwd is a pain ti engage/disengage #9
Or when going slow, tap the throttle in a quick accel/decel fashion as you work the lever and the 4wd usually slips right out when when it's goes through that moment when it's not binding in either direction- like butter.
   / 4520 mfwd is a pain ti engage/disengage #10
I generally will change directions briefly (forward or reverse)... since I might not have the loader attached.
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
Bale Spear - Fits John Deere 300/400/500 Series Carrier (A55218)
Bale Spear - Fits...
2019 KENWORTH T880 DAY CAB ROAD TRACTOR (A51406)
2019 KENWORTH T880...
