4510 Mahindra Cab, LH Door
   / 4510 Mahindra Cab, LH Door #1
SCSRanch
Lapine, LA
'08 4510 Mahindra
I wondering if any knew where and who sells this Dae Kwang Glass for the LH door? Internet not showing it.
Thanks
   / 4510 Mahindra Cab, LH Door #2
16997010151 LH door glass for 4510
Thanks
While we on the subject, do you happen to know the # for the side mirror glass? My brother busted both of them going underneath limbs, thanks.
   / 4510 Mahindra Cab, LH Door #5
The only part of the tractor that is Dae Dong will be the engine. You can order that part number through Mahindra. If you need the gasket it will need to be ordered also
   / 4510 Mahindra Cab, LH Door #6
You will have to get the whole fixture with the glass in it. Or take it to a glass shop and see if they can cut you a glass
   / 4510 Mahindra Cab, LH Door #7
I broke the glass on my right side door on my 4510. The glass was not expensive, I think the shipping was nearly $300, well more than the glass. I have a parts book and got mirrors but they gave me two different sizes, can't believe that is correct and it looks odd. Took them off as they kept get hitting by tree limbs etc. If I remember I will try to get the part number, it is at the farm.
   / 4510 Mahindra Cab, LH Door #8
I checked both options old and new and they are the same part number for the left hand at least. Glass is expensive and it has to be shipped on a big truck instead of ground... that's what eats up the Ft.
   / 4510 Mahindra Cab, LH Door #9
Why not get a plexiglass replacement fitted from local glass shop.
   / 4510 Mahindra Cab, LH Door #10
plexy would be hard to see out of within a year or so of being worked I would imagine.
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
Ford Tractor (A50120)
5ft 3 Point Hitch Bog Harrow (A51573)
5ft 3 Point Hitch...
