451 w/ 1040 loader question
   / 451 w/ 1040 loader question #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
Just bought tractor, was well taken care of but seller did not have tractor long and did not know if this was correct set up: In order for FEL to operate, control lever has to be tied back or it will return to forward position and loader won't move (first pic) Second pic shows where lever connects to rod at hydraulics with control lever forward and FEL not working, third pic shows rod position w/ lever pulled back and loader working. Should nuts on rod be adjusted to hold lever back?, other info appreciated.
   / 451 w/ 1040 loader question #2
Before you go adjusting things.
Go to your dealer and have him order you a new remote end cap. Where the hose is attached in the first picture. Hose goes to loader spool.
Then you need a hydraulic 90 and a tee. Make the left side of the remotes look like the second picture. Top line goes to loader.
Pictures are of a 471. Hope this helps.
   / 451 w/ 1040 loader question #3
Here's a better picture of the second view. This setup will allow you to use the loader at any time and have both remotes free. ImageUploadedByTractorByNet1474593688.023738.jpg
Electric Mobility Scooter (A51694)
Electric Mobility...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2023 CIMC 53X102 REEFER TRAILER (A52576)
2023 CIMC 53X102...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
