4500 psi Pressure Washer
   / 4500 psi Pressure Washer #1
Yooperman
Kubota BX25
First I apologize for posting this under attachments. :ashamed: While not an attachment question per se, it is the closest forum topic I could come up with.
I want to know if a pto pressure washer of 4500 psi will remove a good amount of old paint and rust from equipment before repainting. (ok, it wouldn't have to be pto driven, but it does to fit in this forum heading! :laughing: ) I want to repaint a piece of old equipment without the expense and hassle of taking it somewhere to have it sand blasted. I have a sand blast cabinet for smaller parts, but not the big parts. I don't expect the pressure washer to get it down to bare metal, just good enough for the new paint to be able to adhere.
Thanks to anyone with experience in this area.
   / 4500 psi Pressure Washer #2
I do not know about old paint and rust - but----- my neighbor removed a good deal of new green paint from his brand new JD last year before he quit. It should help .............
   / 4500 psi Pressure Washer #3
I think it will get you down to the metal. I can tell you I had to repaint the front cap on my 2009 Camray after my wife sent my grandson out to clean the love bugs off that she had let dry on the front bumper and fenders with my 3200 PSI pressure washer. I had a rotary nozzle on the pressure washer that will knock rocks out of the cement when I clean the driveway. If you can get a rotary nozzle rated for that amount of pressure it will do wonders. If you do use it, I would be careful not to hit the side walls of the tires.
   / 4500 psi Pressure Washer #4
They make a "wet" sandblasting attachment that you put on the end of the sandblaster that will siphon sand into the water stream. I hear good/bad things about them, but plan to try one someday.
   / 4500 psi Pressure Washer #5
I have a commercial grade 8 hp honda powered unit, and it stripped the clear coat of a car in big strips. Be safe.
   / 4500 psi Pressure Washer #6
They work pretty well depending if you get the pro version vs consumer. The problem is the flash rust before you can get it dry. Tried alcohol (denatured) and it helped but still get some light rust. Some is better than a lot or heavy however which us what you start with.
   / 4500 psi Pressure Washer #7
I suspect a 4500 PSI pressure washer with a 0° nozzle would remove most paint. I have removed old paint off of a rusty implement with a 2500PSI with a 0° nozzle. A 4500 PSI unit should be able to do it better.
I would be concerned about washing an automobile with a pressure washer that was that strong. The 2500 PSI unit I used was an electric Hotsy hot pressure washer and if you accidentally left a 0° nozzle on or go to close you could cause some damage to a nicely painted surface. It did wonders removing strips of decals if you got to close on a Kubota front blade.
   / 4500 psi Pressure Washer #8
I have one of the pressure washer sand blasters. I used it with a 3000 psi pressure washer, and it does a fine job, right down to bare metal.
Trick is to keep the sand pipe on top of the nozzle.
It will spray sand, glass beads, or whatever.
You might even try soda blasters using high pressure air.
BE 85.400.002 3500 PSI Sandblasting Kit
   / 4500 psi Pressure Washer #9
So for those that have used the sand blaster, how big of a mess does it make? Could you use in the yard and not worry about where the sand goes or do you need to do it over a tarp or something?
   / 4500 psi Pressure Washer #10
You can do it almost anywhere.
You might even be able to recover some sand, just filter.
You need protection over your head and face.
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2008 JOHN DEERE 6330 LOT IDENTIFIER 90 (A53084)
2008 JOHN DEERE...
