I bought my Mahindra 4500, 4wd, w/FEL last September. I really didn't have a chance to use it thru the winter months for any length of time per use but I am starting to use it now with a new Wood's 720 brush mower. Here's the problem....After working the tractor for approx 3 hrs under load, the tractor started to sputter and lose power. The fuel gauge showed 3/4 tank full yet but I shut the tractor down and tried to open the filler cap on the fuel tank to make sure I wasn't running low on fuel in case the gauge was faulty. It was a chore just to loosen the cap and then I couldn't even have pried the cap off if I tried. I kept trying to lift the cap off and heard a slight hiss of not pressure but vacumn. It took me a full minute to finally relieve the vacumn and took the cap off. The gauge was right and I still had fuel 6" down. I put it all back to normal and restarted the tractor and all was great. I mowed for another hour without problems and returned the tractor to the shed. I checked the tank once again and vacumn was once again building up.
I called Mahindra Tech Support and now I know how it must feel to go to a psychiatrist. Essentially - you solve your own problems or just live with it.
