45 HP tractor pin category
   / 45 HP tractor pin category #1
KubotaSteve
Platinum Member
eastern panhandle of WV
Kubota B7800 with loaded R-4s
My brother wants to use his wife's uncle's 45 HP New Holland to dig some holes using my post hole digger. I think it is the TN model but not for sure. Does it have category 1 or 2 pins?
He doesn't quite understand what I am talking about, so before dragging the Post hole digger down to his house, I wanted to make sure it would work. I've all ready informed him about the extra HP.
   / 45 HP tractor pin category #2
45 HP tractor could be either cat 1 or 2, probably a cat 1. Just have him measure the pin sizes and let you know which size they are. Your post auger have cat 1 pins ? Get some cat 1-2 sleeves, cheap and no problem, fits anything /forums/images/graemlins/smile.gif
Ben
   / 45 HP tractor pin category #3
Steve, there are no 45hp TNs. Some of them a few years old might be 55hp, but not 45. I think he has a TC and that would be a Cat. 1 3PH.
   / 45 HP tractor pin category #5
Doesn't matter anyways, the implements will fit fine, pins just a bit loose. Makes them easier to connect, cat 1 stuff on cat 2 arms.
   / 45 HP tractor pin category #6
Like the others said. In general.. the cat 1/2 cutoff is right around 45-50 hp. You might find a 50hp tractor with cat 1 arms.. or a 45 hp with cat 2 arms.
As the other poster mentioned.. just get a set of cat1-2 bushings and carry with you..you'll be set to go no matter what he has then.
Soundguy
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2018 Chevrolet Malibu Sedan (A50324)
2018 Chevrolet...
2007 John Deere 5225 (A50120)
2007 John Deere...
2015 Chevrolet Silverado 1500 Pickup Truck (A50323)
2015 Chevrolet...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
