45 HP tractor pin category
   / 45 HP tractor pin category #1
KubotaSteve
Platinum Member
eastern panhandle of WV
Kubota B7800 with loaded R-4s
My brother wants to use his wife's uncle's 45 HP New Holland to dig some holes using my post hole digger. I think it is the TN model but not for sure. Does it have category 1 or 2 pins?
He doesn't quite understand what I am talking about, so before dragging the Post hole digger down to his house, I wanted to make sure it would work. I've all ready informed him about the extra HP.
   / 45 HP tractor pin category #2
45 HP tractor could be either cat 1 or 2, probably a cat 1. Just have him measure the pin sizes and let you know which size they are. Your post auger have cat 1 pins ? Get some cat 1-2 sleeves, cheap and no problem, fits anything /forums/images/graemlins/smile.gif
Ben
   / 45 HP tractor pin category #3
Steve, there are no 45hp TNs. Some of them a few years old might be 55hp, but not 45. I think he has a TC and that would be a Cat. 1 3PH.
   / 45 HP tractor pin category #5
Doesn't matter anyways, the implements will fit fine, pins just a bit loose. Makes them easier to connect, cat 1 stuff on cat 2 arms.
   / 45 HP tractor pin category #6
Like the others said. In general.. the cat 1/2 cutoff is right around 45-50 hp. You might find a 50hp tractor with cat 1 arms.. or a 45 hp with cat 2 arms.
As the other poster mentioned.. just get a set of cat1-2 bushings and carry with you..you'll be set to go no matter what he has then.
Soundguy
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
Bobcat 3400 ATV (RUNS) (A50774)
Bobcat 3400 ATV...
(2) Galaxy 15-19.5 Tires and Rims (A50120)
(2) Galaxy 15-19.5...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
