45-55 hp with Power Shuttle?
   / 45-55 hp with Power Shuttle? #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
After replacing a sync reverser and now have lost 2 gears I want a compact utility tractor with a wet clutch and power reverser. Don't want hydrostatic. Most of the Korean, Japanese and Indian tractors I have researched use a dry clutch and a sync reverser. Is there a specific brand that uses the wet clutch and power shuttle? Or am I going to have to look at $50-60K utilities?
   / 45-55 hp with Power Shuttle? #2
Check out the TYM/Branson 5835 but it might be on the bigger size for your liking.
I think it's about the smallest one with power shuttle though.
Edit: I think they'll be releasing a cab version of it sometime this year.
   / 45-55 hp with Power Shuttle? #3
I bought a very nice 2002 Massey Ferguson 451, 52 HP utility tractor with shuttle--shift and FEL for $14k last summer. I've been very satisfied with my purchase.
   / 45-55 hp with Power Shuttle? #4
Yanmar YT347/359 with the iHMT. 10 year power train warranty. Puts more power to the ground than a HST.
   / 45-55 hp with Power Shuttle? #5
Kubota M5660SU if the size isn't to large.
Hydraulic shuttle, no clutch pedal needed to shift F-R. I have a larger one with zero issues so far on the shuttle.
   / 45-55 hp with Power Shuttle? #6
Dry clutch tractor.
   / 45-55 hp with Power Shuttle? #7
Massey Ferguson 2860M is right within your power and budget range.
Edit: sorry, I miss read the last sentence...
There is an 1840M power shuttle as well; but the 2850/60M isn't that much more for a good bit more tractor.
   / 45-55 hp with Power Shuttle? #8
Anyways, on Power Shuttles, I really like them in construction equipment, and in tractors; But Try to test drive the specific machine you are buying. Some of them are already bit jerky when moving from F to R. It can be adjusted on some, but make sure it's something you can live with. BTW, some are very very smooth, that's why I say try the machine.
   / 45-55 hp with Power Shuttle? #9
TYM T4058P is the only option available. They will be released soon.
CABIN
OPEN STATION
   / 45-55 hp with Power Shuttle? #10
Kubota's shuttle shift (as stated above) requires clutch depression for directional change & is a dry clutch type
hydraulic shuttle is a wet clutch pack & does not require clutch depression. a wet clutch pack is considered more long lived than the dry type.
2018 JLG 3246ES 32FT. Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2014 Kia Optima Hybrid Sedan (A50324)
2014 Kia Optima...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
Skid steer auger plate (A50322)
Skid steer auger...
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
