448 backhoe mounted on new 4520 Cab
   / 448 backhoe mounted on new 4520 Cab #1
xrjohndeere
Mo
2021 Kubota L4060 HST
Just thought I would let you guys know I got my new 4520 JD w/cab last week. I kept my old 400cx loader and 448 backhoe and brackets. The brackets I had to modify to fit the new cab tractor. What I had to do was cut 3" off the front of both brackets and cut the top of the right one down a little to clear the cables for the loader valve underneath where the computer is. On the left side I had to take off the bracket that the range control lever connected to and cut it and weld it to the backhoe side plate. Had to cut a few pieces of steel on the BH bracket down where the cable would go through and then bolted it up. It really was not too much trouble. John Deere wanted $1800 for the new brackets for the cab tractor. Pretty expensive half inch plate steel! Where I had to cut the brackets there was no loss in strength. I hooked up the backhoe and it fit just fine. No issues with clearance of the back glass. The loader I was not able to hook up because John Deere changed the size of the hydraulic couplers on the tractor so I will have to go to JD tomorrow and get new ends. All I have to do after that is hook up the stereo and the rear work lights. Hope to get Pics soon.
   / 448 backhoe mounted on new 4520 Cab #2
Lookin' forward to seeing your modifications. Most folk's would have resigned themselves with buying new attachments -- you got quite a bit more "can do and will do it myself" in the tank..
Congrats on your new tractor and your ingenuity. :thumbsup:
AKfish
   / 448 backhoe mounted on new 4520 Cab #3
Preserverance pays off, glad to see you have the backhoe mounted.:thumbsup:
Waiting for pics of that bad boy.
Truck Tool Box (A50774)
Truck Tool Box...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2022 CATERPILLAR 272D3 WHEELED SKID STEER (A51242)
2022 CATERPILLAR...
UNUSED FUTURE MINI SKID STEER HYD 4IN1 BUCKET (A51244)
UNUSED FUTURE MINI...
