445 - 2" receiver setup at rear hitch. Options?
   / 445 - 2" receiver setup at rear hitch. Options? #1
MISparty
John Deere 445
I've seen a couple of pictures with a 2" receiver setup attached to the rear without a 3-pt hitch. I DO have the click-n-go system in place.
I've looked around, but can't find something that would hook up directly.
Here's a picture of one I found - but didn't know if it was commercially available, or just something that was fabbed up.
Thanks!
   / 445 - 2" receiver setup at rear hitch. Options? #2
Likely fabbed to the triangular hitch plate that is at the rear.. is what my 455 has. I bolt a receiver to that.
Thanks - so nothing necessarily stock for these then from what it sounds like
   / 445 - 2" receiver setup at rear hitch. Options? #4
I have seen receivers that bolt on to the drawbar on e-bay.punch in jd 445 and scroll around
   / 445 - 2" receiver setup at rear hitch. Options? #5
I've bought some things from a fellow on ebay. His work is excellent and the items are just beautiful! Let me find his contact info for you. His handle on there is tractorace09. See if that gets you anything.
   / 445 - 2" receiver setup at rear hitch. Options? #6
I got a 2 receiver hitch from TSC that bolts to the draw bar. It was made for a class one hitch, I bent the gussets out of the way because they were to wide to fit the draw bar. I will try to post a picture tomorrow.
   / 445 - 2" receiver setup at rear hitch. Options? #8
Oh sorry, rereading I see you do not have a 3 point.
   / 445 - 2" receiver setup at rear hitch. Options? #9
I'll look at mine after while and try and post a picture. I just took a 6 inch long trailer reciever piece from our farm store and welded on some studs so I could put it thru the stock holes and bolt it on.
   / 445 - 2" receiver setup at rear hitch. Options? #10
Would like to see a pic of that fab, Capt Dan. :thumbsup:
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
John Deere 772-A Grader (A52384)
John Deere 772-A...
