Tires 4410 R4 tire owner help needed
   / 4410 R4 tire owner help needed #11
i have the R-4 tires on my 4410,as i mostly use my machine on hills i am always in 4WD and as long as you don't turn to sharp it won't tear up the turf even in 4WD.since my property is mostly wooded and in the shade it does'nt get a chance to really dry out and i have'nt had any problems with tearing the ground up.i do alot of 2 point turns to avoid it and have had success.my tires are'nt even filled
   / 4410 R4 tire owner help needed #12
Ron
I'm not so sure changing to R-4's will solve your problem.
Here is a thread with plenty of coments from fellow TBN'ers on all 3 types of tires.
Click Here
I have turf tires on my B2910. If I wanted to avoid getting stuck in mud I would change to R-1's. I doubt that R-4's would be much if any better than the turfs on my tractor.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2022 Lonestar (A55973)
1449 (A57192)
1449 (A57192)
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
