440b bobcat
/ 440b bobcat #1
don mason
omaha neb.
Bobcat 4040b
I have a 440B bobcat, it runs for about a half hour and then just shuts down like its not getting any gas. will start right back up after dies. added oil, changed plugs, new gas filter, new air filter--nothing seems to help. Any ideas?
/ 440b bobcat #2
Did someone add an electric fuel pump, like a Mr. Gasket pump from an auto parts store..?? A PO did on my 450 w/Kohler power, and had similar problems. Tried a couple news ones, and was good for a while, but then acted up again. Apparently those little pumps get so hot, they will stop pumping fuel. Not sure if the little oscillating piston in them binds or what, but you can tell more by the sound when they do it. Even went as far as buying a pressure regulator w/return line, and still had the same problem.
I bought a new OEM manual fuel pump for it, and never had the problem again.
It's much easier to install with the engine out. And it's not that bad of a job to take it out. I just cribbed up, and had a section of plywood on top of the cribbing to slide it out on, and worked on it there. It was about a two hour job, in & out, and I took a couple coffee & smoke breaks.
This was about 4 years ago, and OEM fuel pumps then were right at $52.00. Money well spent.
2023 Kubota SVL97-2 Compact Track Loader (A63118)
2023 Kubota...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2004 CATERPILLAR 242 SKID STEER (A64279)
2004 CATERPILLAR...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
2018 John Deere 8345R MFWD Tractor (A63109)
2018 John Deere...
