Price Check 4400 price check
/ 4400 price check #21
You are probobly out signing papers by now, but in case you aren't, and STILL havent made up your mind, allow me to throw in some mud. I spent 4 hours mowing brush in the woods yesterday on a L4610 hydro with a 2560 woods cutter.
I used to cut with a Case IH 255 (24 horse Mitsubishi) and a 503 JD cutter (believe it's the early version of the 513) The tractor was half the size of the Kubota but the mowers are the same width.
I am able (and WILLING) to get into TIGHTER spots with the larger tractor because of the hydro. I can creep alot better with more control. I cut more with less effort. The mower and tractor worked easier because I did not use the clutch.
The 513 JD mower cost half of what I paid for the landpride 2560 ( I just saw the Brushbull, and think I would have bought it had I seen it first, very nice and very stout) BUT the JD was shot after 4 seasons of use. The gear box was alive, but the sheetmetal was toast. I dont think it would have lasted that long on the Kubota with 39 HP.
Coverage- my wheels are just about the same width as the cutter housing, if I were in an open field I would want a wider mower, in the woods, narrower. Since Homer Simpson was mentioned, he once reached his arm into a soda machine and got stuck. 4 hours later the rescue squad gave up trying to extract him. Finally someone said "Let go of the can Homer!" That is somewhat like mowing in tight timber with a wide mower.
/ 4400 price check #22
The 513 of mine, after about 2 weeks I had to take it to the welding shop and have 3/8 reinforcement on the back of the cutter after I straightened it out with a sledge hammer,the sides need the 3/8 installed as well and it will be an ok cutter. The gearbox seems ok and the part the wheel etc is attatched to is stout enough but the housing is made out of recycled bean cans,I have seen better metal in throw away pie pans.
/ 4400 price check
Well guys, just got back from dealer and got a final final quote. Still 28,175., but, includes MX-5 rotary cutter which brings me up to about 21% off list price. He had some interesting things to say about his trip to NM.......TNT will be included on the new 10 series. also, hydrostatic will be built by different mfg who will test each one before it leaves for the dealers. Extra scv's will be installed at the factory rather than at the dealerships. Hydrostatic control will be electronic rocker switch for better feathering. And the new series will have true cruise control rather than just a hydro-pedal lock. Hey kerr! I tried for the toothbar, but he said they didnt carry them ( does any one know if JD makes and sells them or not?)but, he did throw in the 6-ply R-1s. Also having twin 50w halegens on ROPS and 55a alternator added. Told him I'd (we'd) come back on wed. the 8th. (I needed to cool my heels and think some more......'whew') Well guys , what do you think? Good, Fair deal? Your input is greatly appreciated! Also, does anyone out there know anything about land pride HD25 series bucketmount hydralic posthole auger? Any one out there have one and if you do, how do you like it? Thanks guys......Im listening......
/ 4400 price check #25
Gonna be a looooonnnnggggg week ,fer sure!Sounds like a hech of a rig guy.The 513 cutter is the only cutter i have ever owned.I worked at a VERSITILE dealership in KS. for a short time the sold alot of BUSHHOG impl.Happy hunting!
2008 Hummer H3 4x4 SUV (A66738)
2008 Hummer H3 4x4...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
2000 Hino (A64194)
2000 Hino (A64194)
2016 MACK GRANITE(INOPERABLE) (A67714)
2016 MACK...
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
MARKER LIGHTS (A64276)
