4400 blowing fuses
   / 4400 blowing fuses #1
dqdave1
N. E. Ohio
tc- 29d
4400 hydro is blowing fuses at the headlight switch ( 30 amp?) and the taillamp, hazard fuses are blowing also. Any suggestions? Headlamp switch bad?
   / 4400 blowing fuses #2
Do you leave the machine outside? It sure does sound like the switch went bad...do the fuses blow only when the switch is operated?
Yes, the fuses blow when switch is used. and, yes, the machine has been sitting out in the weather.
   / 4400 blowing fuses #4
I think you've answered your own question:D
   / 4400 blowing fuses #5
Has to be a short. Unfortunately, these can be the most troublesome problems to diagnose. I agree with Kennyd -- look for a bad switch first. You can confirm a short in the switch with a VOM meter or just replace it.
thanks for the replies.
   / 4400 blowing fuses #7
If the switch isn't filled with water, I'd look for a pinched or worn wire that is grounding out.
New CFG 680 Skidloader Pounder (A50775)
New CFG 680...
SKLP Windmill Shooting Target (A53316)
SKLP Windmill...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2019 Ford F-550 4x4 Altec AT40G 40ft Bucket Truck (A55788)
2019 Ford F-550...
2021 Ford F-150XL (A53314)
2021 Ford F-150XL...
