43x16x20 Tire Chains
   / 43x16x20 Tire Chains #1
mattisjd
Rochester,NY
LS R4010
So, I want to get a set of double ring chains. I cant' seem to find a set to fit my tire size, 43x16x20. So, I'm hoping that someone has a similar tire that can help me out. Does anyone know what other sizes are close to this? Will chains for a 12.4x24 tire fit this? I'd appreciate any input you guys might have.
   / 43x16x20 Tire Chains #2
Give a look at the tire chain.com website.tractor tire chains for farm tractors
I would call them up and ask them if they have some for what you are looking for. They are very good to talk to.
Thanks, I did email them already and they told me all they had was the agricultural ladder style, which I don't want.
   / 43x16x20 Tire Chains #4
I have DUO's on my DK35SE's 43x16-20 tires. I finally got them to fit after much work. Here is a link to modifications I made:
http://www.tractorbynet.com/forums/attachments/268885-duo-chains-planned-modifications.html
If doing it again I would go with something like Aguilines, Trygg's, or Tellesfdals.
One thing I found for the DUO's and other chains with patterns that go straight across the tire (as opposed to Aguilines, Tryggs, etc that have a continuous pattern going around the tire's diameter) is that for small, wide tires such as the 43x16-20 you likely want shorter cross-links than most recommended. That places the chain higher on the sidewall giving more cross patterns in the chain, more grip, and a smoother ride(although still rough on hard ground with DUO's).
Here's a link to a similar thread:
http://www.tractorbynet.com/forums/snow-removal/326592-tire-chains-my-tractor.html#post3979120
The thread has links to Aguilines, Tryggs, Tellesfdal chain info.
2022 INTERNATIONAL MV607 (A52472)
2022 INTERNATIONAL...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
