4366 hydraulics
   / 4366 hydraulics #1
derrick9415
Scobey, Mt
I have a 4366 IH and want to pull a air drill with it. Can anyone tell me what I have to do to make my hydraulics work with the hydraulic fan? Thank you.
   / 4366 hydraulics #3
http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/eng8090
If the fan is rotated by a hyd motor, then you need a supply of fluid through a motor valve.
It depend on what you have now. Can you describe your hyd system, such as, I only have a hyd pump and 3pt, or something similar.
If you do have remotes, you plug in the hyd hoses to the remotes and bungee the valve spool open for hyd fan operation.
2014 FORD F150 4X4 CREW CAB PICKUP TRUCK (A52576)
2014 FORD F150 4X4...
MacDon C3012F Corn Head (A53342)
MacDon C3012F Corn...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2019 JOHN DEERE 5090M LOT NUMBER 93 (A53084)
2019 JOHN DEERE...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
