4320 John Deere Radio Install
   / 4320 John Deere Radio Install #11
here's another idea. lots of car sterio places offer free installation, maybe if you bought a radio from one of them then they would install it.
   / 4320 John Deere Radio Install #12
Mjncad
That is some really good advise-:)
Sorry for the duplicate post :eek: :eek:
   / 4320 John Deere Radio Install #13
Mjncad
That is some really good advise and great information-:)
   / 4320 John Deere Radio Install #14
Search the forums and talk to a JD dealer. Do not trust an auto radio installer to do it! I have seen some good info on here about it but can't find it now!
   / 4320 John Deere Radio Install #15
I just purchased a 2009 JD 4320 tractor with cab,but it did not come with a radio already install .Is it very hard to install one?Also tell me all the parts needed.Does the wiring already exist in the cab?
I mounted the radio in my 3520. I did a search here and found some interesting threads on doing this. I went to my local radio install shop and purchased the connector. If I remember it is a VW connector that will plug into the radio and the tractor wiring. I also purchased the speaker kit from JD. After that it went well.
You will have to remove the top of the cab and be very careful of the foam seal strips or get new ones. That's what I did. If you end up with a break in the seal it WILL affect your cooling. Be careful with the speaker covers. The mounts can pull loose pretty easily.
Good luck and have fun
   / 4320 John Deere Radio Install #16
I have a 2010 4320 with a radio but it sounds like I only have a single speaker. I would like to take the top off the cab and check to see if I have two speakers but I'm almost afraid to because it may ruin the seal. Does anyone know if there should be two speakers. I would think there would be two at least.
   / 4320 John Deere Radio Install #17
John Deere has the radios and speaker kits available. The kit is part number LVB24953. It contains the antenna, wiring and two speakers. Our local dealer has several radios to choose from. All were Jensen radios. I don't think it would be very hard to install. The dealer told me to take out the headliner and it would be easy. He said the headliner isn't too hard to get out. The surrounding trim is what holds in the headliner. He said the radio has two screws to hold it in. I am having the dealer replace my left speaker since it didn't work. My warranty covered the tractor or I would have tried to fix it myself. Good luck with yours.
2015 CATERPILLAR CT660 TANDEM AXLE DUMP TRUCK (A54313)
2015 CATERPILLAR...
2016 Genie S-45 4x4 45FT Telescoping Boom Lift (A55787)
2016 Genie S-45...
(4) GOODYEAR WRANGLER 275/55R20 TIRES (A54757)
(4) GOODYEAR...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
