4320 Coolant Lead from Timing Cover
   / 4320 Coolant Lead from Timing Cover #1
gbw
Bronze Member
2006 model 4320, 900 hrs, that I love has developed a coolant leak around the timing cover. I understand this is a fairly common problem wit this model and is difficult and expensive to fix. Oh well.
My question is whether it's risking further damage to wait on this repair for a couple months - I have a project going on and I need te tractor until it's finished. Keeping an eye on coolant level of course, but that won't be a problem.
HOWEVER, if it will damage the engine further to run it with this leak I'll find a way to have the work done now. But I'd rather wait until I'm finished if I can.
Thanks,
gbw
   / 4320 Coolant Lead from Timing Cover #2
Depends on if Any coolant is getting into the engine, if it is getting into the oil, it WILL damage engine bearings.
   / 4320 Coolant Lead from Timing Cover #3
Agreed! I would not risk my tractor to finish a project. I would also drain the engine oil and check it for coolant to confirm coolant is getting into the engine. Even if none found, I would not risk my engine.
LINEAR COMPRESSOR FRIDGE / FREEZER COMBO (A57192)
LINEAR COMPRESSOR...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2019 Yongfu Scooter (A55853)
2019 Yongfu...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2016 Volkswagen Jetta Sedan (A55853)
2016 Volkswagen...
148in Roll up Door (A55852)
148in Roll up Door...
