4320 Coolant Lead from Timing Cover
   / 4320 Coolant Lead from Timing Cover #1
gbw
2006 model 4320, 900 hrs, that I love has developed a coolant leak around the timing cover. I understand this is a fairly common problem wit this model and is difficult and expensive to fix. Oh well.
My question is whether it's risking further damage to wait on this repair for a couple months - I have a project going on and I need te tractor until it's finished. Keeping an eye on coolant level of course, but that won't be a problem.
HOWEVER, if it will damage the engine further to run it with this leak I'll find a way to have the work done now. But I'd rather wait until I'm finished if I can.
Thanks,
gbw
   / 4320 Coolant Lead from Timing Cover #2
Depends on if Any coolant is getting into the engine, if it is getting into the oil, it WILL damage engine bearings.
   / 4320 Coolant Lead from Timing Cover #3
Agreed! I would not risk my tractor to finish a project. I would also drain the engine oil and check it for coolant to confirm coolant is getting into the engine. Even if none found, I would not risk my engine.
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
John Deere Z540M (A56469)
John Deere Z540M...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
John Deere skidsteer (A55788)
John Deere...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
19015 (A55788)
19015 (A55788)
