4320 3rd SCV Addition Questions?
   / 4320 3rd SCV Addition Questions? #1
JDRULES
Western New York State
JD 4320
I have a 2014 4320 with a 400x FEL and no rear 3rd SCV that I would like to add. Would anyone have experience adding this themselves? What is the proper kit number for this year model and rough cost? Would anyone also have a pdf copy of the installation instructions that they could share so I could get a feel for all that would be required to complete the install? Any photos or video links of the install would also be great. Thanks.
   / 4320 3rd SCV Addition Questions? #2
JDRules
Look at the similar threads listed near the bottom of this page for a few of the many posts on TBN that are about what you want to do.
Not the same, but I had no trouble adding the 3rd SCV kit to my JD 4300 and suggest the first thing is to see if your Deere dealer has such kit for your 4320.
Just removed the right rear tire and fender, followed the instructions. Minimal talent needed to make the change IMO.
   / 4320 3rd SCV Addition Questions? #3
Is this cab or OOS tractor. What the last 6 of your serial number and I'll tell you what kit you need.
916,000 something. Sorry, I'm not where I can exactly get it.
Thank you. Would you know what is also required to run lines to my 400x loader bucket to run a grapple and what is needed to add a 4th & 5th rear SCV? Any known rough cost estimates for each installation?
   / 4320 3rd SCV Addition Questions? #8
Okay for 3rd SCV kit number is-- LVB26032 for OOS only
For a 4th and 5th SCV kit number is-- LVB26037
To install those kits a dealer will charge around $800-$1000 to do both. That's just labor. 3rd SCV Kit is about $1200 and the other is about $900.
   / 4320 3rd SCV Addition Questions? #10
I have 2 open station 4720 and have 3rd 4/5 scv on both I had dealer put all three on one tractor when I bought it and the other tractor only came with the 3rd scv and I actually just put the 4th and 5th on this week. It is really simple to do . I just took of the seat assembly 4 bolts and 2 electrical connector one for safety switch in the seat and one for the air ride seat then I unbolted the black plastic panel that is under the seat between the fenders its like 8 small bolts and just propped it up then I had to remove the bolts holding the ecm and one bracket and the loader valve is right there and easy to get wrenches on to hook up the steel lines that go to the valve . It shouldn't take more than 10- 15 minutes to remove the seat and plastic cover. The knob that adjusts the draft arm speed just pull straight off and if you have a hydro the Orange cap pops off the shifter and there is a nut under it to remove the knob. After doing this my self I think what the dealer charges for labor is rediculous .
For running the 3rd scv to the loader they just made rubber hydraulic lines and zip tied them yo the steel one that run to were the loader line plug in . Il try and snap some picture this afternoon
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
UNUSED FUTURE...
2021 CATERPILLAR 306 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
2016 Ford Taurus Sedan (A56859)
2016 Ford Taurus...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
