Snow 4310 with Power Reverser
   / 4310 with Power Reverser #1
Ed Vanden Brand
Edmonton, Alberta
John Deere 5325 & 4310
I have a power reverser on my 4310. When operating tractor it will quit going in gear and the orange light start flashing.
I talked to the John Deere dealer and he said change oil both filters and clean screen which I did and made no difference. If you keep trying you will get it to
go and will keep going until you change directions and then will quit again. Anyone have any ideas or had this happen and know what to do?
   / 4310 with Power Reverser #2
What is the sequence of codes flashing? Example would be two long and two short flashes. I think the power reverser may have 5 flashes to the code.
I love how that "recommendation" is he first thing out of the dealers mouth. What that should tell you is: We do not know how to fix it, so we will recommend throwing parts at it. Would you like to buy a new one from us?
This one is a good tractor with only 410 hours on it, don't think I will give up on it yet.
I will have to check the flashes next time I try it. Wonder if I count the flashes if the JD dealer could tell me what is wrong?
   / 4310 with Power Reverser #5
The code sequence is only 3. It will be like two shorts and then a long followed by a break then it will give the next code, if it is the same you only would have one code in there.
   / 4310 with Power Reverser #6
Change the fluid was what they told me on mine. I am quite sure I now know more than MY dealer about the 4310.
2002 Ford F-650 Landscape Flatbed Truck (A56858)
2002 Ford F-650...
2016 International DuraStar 4300 S/A Cab and Chassis Truck (A56858)
2016 International...
Weld on excavator thumb EK1212 (A56436)
Weld on excavator...
1991 Eager Beaver 24ft. T/A Dovetail Equipment Trailer (A56858)
1991 Eager Beaver...
3" X 3" GAS POWERED WATER PUMP (A52708)
3" X 3" GAS...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
