Tires 4310 wider front tires, industrial
   / 4310 wider front tires, industrial #1
Tororider
SE Michigan
JD 4310
I was wondering if anyone has, or knows if any are available. I am looking for wider industrial front tires. The normal industrial tires, 25x8.5-14.00 tires on 14x6 rims I think, are ok, but dig/sink in pretty good when the ground is at all wet. I am wondering if there are wider, not bigger, tires available anywhere. I would think that as long as the diameter of the wheel is the same it wouldn't matter how wide it is, am I right?
   / 4310 wider front tires, industrial #2
I used Turf Specials on the front of my former 4310 and those wored pretty well. but they are designed for golf courses.
   / 4310 wider front tires, industrial #3
I use a set of 26x12x12 tires commonly found on the rear of larger lawn tractors on the front of my 4300 for lawn mowing but their far too light duty for loader work.Diameter wise there almost an exact match and I found a set of rims off an older cub cadet (I believe) that even had the correct 6x6" bolt pattern and bore size.I do however go back to stock tires for snow plowing and loader work.
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
