4310 Mystery Wire
   / 4310 Mystery Wire #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
Hello,
I was doing some clean up work inside my 4310 and came across this single wire that seems to be attached to the back of the fuse box. Has anyone seen this wire before? Do you have one in your 4310? Do you know what it's for . . . or gets connected to? Any information at all would be appreciated.
FredSG
   / 4310 Mystery Wire #2
I have a "spare" wire coming out of the back of my fuse box also.I bought the tractor new and it was never attached to anything. This is assuming that we're both talking about the same wire. I now use that wire as a keyed power for a fan that I use when mowing ditches.
   / 4310 Mystery Wire #3
Plug something (light bulb, volt meter, etc.) into it and observe if 12V and/or when it is powered and when not.. Should give you a clue what it is... let us know what you find out.
Do you keep your left/right brakes locked just for road travel?
   / 4310 Mystery Wire
beenthere,
Used my Voltage Continuity & Current Tester and plugged it into the female end of the "mystery wire" with the key off, in the ON position, and with the engine running. No indication of current; must be a dead wire, unless I did something wrong in my testing.
My brakes are always locked.
FredSG
   / 4310 Mystery Wire #5
beenthere,
FredSG
Did you test the wire using the 'lights' switch? I know that there's a single (paired) male & female bullet plug for hooking up auxiliary/work lights... it's wired to the lights switch.
   / 4310 Mystery Wire
Wagtail,
Thanks for the suggestion . . . I'll give that a try tomorrow. Thanks for replying, very much appreciated.
FredSG
   / 4310 Mystery Wire #7
Fred,
I did a little digging into the mystery wire and found it on the same side as yours on my 4310. It seems to be powered off of the #5 fuse which is just labeled KEY ON on the tractor panel. When I pulled the #5 fuse it took power off the mystery wire and also disabled the instrument panel and the fuel cut off solenoid. I think the mystery wire may have been for a diverter valve to operate optional rear remotes off the third SCV section but that is just speculation on my part based on the X3 connection listed in the service manual wiring diagram.
According to the service manual wiring diagram Fuse 5 branches off to:
X3-W1 Main Wiring Harness to W8 Diverter Valve Wiring
Harness.
X5-W1 Main Wiring Harness to W2 SST Jumper Wiring
Harness, or W3 ePowrReverser Wiring Harness, or W4
eHydro Wiring Harness
S2-Seat Switch
S4-Park Brake Switch
S5-Rear PTO Switch
K14-Mid PTO Interlock Relay
and
X8-W1 Main Wiring Harness to Instrument Panel
I don't think I want to plug anything else into it. If you decide to use it you might want to up the #5 fuse to 30 amps. A 30 amp fuse would carry more current and still blow in the even of a dead short.
   / 4310 Mystery Wire #8
FredSG gave better pics of what was behind that "dangling wire" on the GT forum.. he is working both sides.. just sayin
   / 4310 Mystery Wire #9
Hi Fred,
Last night I was doing some research online.
On here I came across your post.
My husband & I have a John Deere 4310 tractor too.
We are repairing the tractor. We bought it at a mahindra dealer, the tractor was flooded.
we also came across the same exact wire as you.
This is the RED 562C. it's near the clutch pedal.
The function of the wire is for cruise control & it's for the diverter valve
I can send you a PM with a copy of the service manual if you like.
Bonnie
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
2013 Audi Q7 AWD SUV (A55853)
2013 Audi Q7 AWD...
2015 Chrysler Town & County Van (A55853)
2015 Chrysler Town...
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
