4310 Joystick Sticking
/ 4310 Joystick Sticking #1
TMcD_in_MI
NW Lower Michigan
JD 4310
Does anyone know how I can fix a sticking joystick on my 4310 with 230 hours on it? It just started doing this a few weeks ago. I can free it up by working it back and forth a bunch of times, but the next time I use the tractor it sticks again, in both left-right and forward-backward motion.
It seems to me like something needs lubing, and I have pulled the joystick boot off to see what I might lubricate. It's not obvious, at least to me, what might need a little spritz of oil. Also, the linkage is tucked under a cover and not easy to get to.
Another TBN member had the same problem last year, but said only that the dealer took care of it. I like my dealer, but his service guys don't work for free.
I'd appreciate any thoughts.
Tom
/ 4310 Joystick Sticking #2
Just to make sure you really have a problem, does it always stick either forward or right? If so, that isn't a problem, it is a feature. On the forward it puts the bucket in "float" and to the right it puts it in "dump". If you're aware of these features and the problem is something else, I apologize for bringing it up. But, sometimes the simplest answer is the right one.
/ 4310 Joystick Sticking #3
We had this problem on our 2002 4310. To resolve it, I had to take off the seat in order to gain access to the ball joint ( I think it's actuall called a hyme joint?) used to connect the stick to the DSCV -- lubing the joint took care of the problem. I never was able to free the joint simply by quirting WD40 or another lubricant up into the general vicinity from under the fender. It takes a ridiculous amount of time (approx. 45 minutes) for such a simple fix!
JEA
</font><font color="blue" class="small">( We had this problem on our 2002 4310. To resolve it, I had to take off the seat in order to gain access to the ball joint ...
)</font>
Thanks JEA. I was afraid of that. Oh well, if that's what it takes, then I'll do it.
Tom
2001 WESTERN STAR  4900E (A67714)
2001 WESTERN STAR...
CAT 631C Lift Cylinder (A68134)
CAT 631C Lift...
2017 Crane Carrier Co. T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
2018 Nissan Frontier Ext. Cab Pickup Truck (A66736)
2018 Nissan...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
