4310 fault code help!!!
/ 4310 fault code help!!! #1
ced
illinois
john deere 4310
The 4310 is blinking a short then 2 longs and another short. Cruise control doesnt work. I believe it is related to the mfwd speed sensor. Anybody know the diagnostic procedures for checking out this fault code. Thanks ahead for any help.
/ 4310 fault code help!!! #2
Would your service manual or CD have the codes? The dealer is always helpful. I would suggest that you disconnect the battery and wait a minute and reconnect the power. This resets most computors, your car, the one you are currently using etc. The code may go away and your cruise will return but it does not answer the question as to why you had the problem. ---Fuseboxer
/ 4310 fault code help!!! #3
While I can not answer your question. I suggest you look at selectmanuals.com. You can get the tech manuals for $24.95.
4210 4310 4410 Tractor - TM1985
This invaluable technical manual CD includes all needed instructions to maintain and service your equipment using detailed diagrams and manufacturers specifications.
Navigation is simple with convenient chapter bookmarks and ability to search by keyword. Print out entire manuals or just what you'll be working on!
The manual details how to maintain, repair and replace all tractor assemblies and following core components.
Replaced the mfwd sensor, problem solved!
25in Wagon Wheel Chair (A65583)
25in Wagon Wheel...
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
2014 MACK GRANITE (A65643)
2014 MACK GRANITE...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
