4310 Dash Fogging - Several tries with no fix.
   / 4310 Dash Fogging - Several tries with no fix. #11
Take it back to your dealer. They will put you in a new anti-fog len, at no cost. It is a known issue.
   / 4310 Dash Fogging - Several tries with no fix. #12
My 4600 also fogs when hot. Keeping the radiator pre-screen
and fins hosed out with water does reduce temp/fogging.
Also I have had 10 different compact tractors of all colors and this is by far smoothest and most comfortable yet. The fogging is my only complaint.
   / 4310 Dash Fogging - Several tries with no fix. #13
I wonder if a small bead of clear silicone sealant around the edges of the plastic over the instrument cluster would help?
   / 4310 Dash Fogging - Several tries with no fix. #14
my 4600 does the same. My dealer knows about it and when I take it in for my final check before warranty expiration /forums/images/graemlins/frown.gif they are going to fix it. That and a few other things... /forums/images/graemlins/wink.gif
-Bob
   / 4310 Dash Fogging - Several tries with no fix. #15
Mine, of course, started fogging AFTER warranty expiration. /forums/images/graemlins/crazy.gif Does anyone know what, exactly, is needed for the fix and what it costs? Honestly, it doesn't bother me but if it's cheap enough I might pay for the part next time I'm at the parts counter for somethting. Thanks. /forums/images/graemlins/smile.gif
   / 4310 Dash Fogging - Several tries with no fix. #16
When hot my 4700 bezel would look like it was covered with white paint. Dealer replaced the bezel with a special treated version. My bezel still fogs a little, but I can read the gauges. I live in Florida.
   / 4310 Dash Fogging - Several tries with no fix. #17
Alot of us complained about this in an earlier thread. The dash on my 4610 fogged up after only 10 hours. Dealer replaced the whole console at 34 hours. Problem still exists, especially after an hour or so of 2300 rpm bush hoggin, and to add insult to injury, changing the console started my hour meter over at 0 hours again. Now I have to remember to add 34 hours for service intervals. /forums/images/graemlins/frown.gif
   / 4310 Dash Fogging - Several tries with no fix. #18
well,at only 2hrs from new my 4410 did the same thing,,,,,,,,,,
   / 4310 Dash Fogging - Several tries with no fix. #19
When I was using my dad's 5320 the other day I noticed the dash started to fog up just like the old 4300 used to do except the 5320 has a cab.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2016 Ford Transit Connect Cargo Van (A56858)
2016 Ford Transit...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
