4310 battery spew warrant fix
   / 4310 battery spew warrant fix #41
I think only the larger framed 4000 series have the oil cooler. If not I never noticed it either. I know the 990 does not have one.
   / 4310 battery spew warrant fix #42
Yeah, I looked again.. no oil cooler I can see.
But.. at the risk of belaboring this thread to death.. I'm not happy with what I've got happening at the moment, and I don't know enough about what I'm doing.
Okay, I got the nut off on the negative terminal, but the one on the positive terminal broke right off. Okay, so I need a new nut/bolt for this. Now I find that the cable on the positive terminal can be moved by hand, so can be removed. The cable to the negative terminal, the one which I successfully removed the nut from, absolutely refuses to budge. I mean serious force won't even wiggle it.
So I said, okay, now I have to wonder what will happen if I apply more force, perhaps rap on it, etc. What if the post itself snaps off and I'm sprayed with acid? What if the pounding causes a spark, and I may have caused a leak by doing the pounding on it? Or what if I just cause a leak, and some future spark ignites it?
So, while pondering the above, I then I address the clamps holding the battery down to the base. One will come lose easily, the other is frozen so solid I'm sure I'll just strip the head off the bolt if I apply any more force.
At this point I said, hmm, this is getting to be a pain, and I don't know enough about batteries to know what's safe to do and what isn't. Maybe the best thing to do is just call the dealer, who has a mechanic who lives near me and drives by here on the way home, and ask them to have him bring out a new battery and install it for me. I'll explain about the bolts and nuts and corrosion/frozen parts problems, and make sure they bring some extras in case they need them (and I know I need at least one.)
I admit it.. I'm a wimp and not terribly mechanically inclined and probably lack the correct tools for the job /forums/images/graemlins/confused.gif (and don't weld) but at least I'll be a wimp who hasn't been blown up, blinded by acid, caused himself major repair bills, etc. /forums/images/graemlins/grin.gif I learned one lesson, at least.. key an eye on that battery and deal with problems before they get out of hand!
Who ever heard of a tractor guy who can't change a battery??!
/forums/images/graemlins/blush.gif
Bob (hiding his face in shame)
   / 4310 battery spew warrant fix #43
Hey don't worry. I'm not the best with mechanical stuff either. That's a good idea to have a mechanic to come out and do it for you. I hate jumping batteries at work since I don't want them to blow up on me. I'll admit I'm afraid of batteries too. About those clamps, if it is like my 990 then you will have 2 nuts on top of a long screw. Just turn them the opposite way and they should come free. I had to wait until my brother came and showed me how to remove the battery.
   / 4310 battery spew warrant fix #44
</font><font color="blue" class="small">( Hey don't worry. I'm not the best with mechanical stuff either. That's a good idea to have a mechanic to come out and do it for you. I hate jumping batteries at work since I don't want them to blow up on me. I'll admit I'm afraid of batteries too. About those clamps, if it is like my 990 then you will have 2 nuts on top of a long screw. Just turn them the opposite way and they should come free. I had to wait until my brother came and showed me how to remove the battery. )</font>
Thanks.. I feel better! /forums/images/graemlins/grin.gif
When I removed the nuts on the negative side, they came right off but the cable won't come off the battery post.. it's like it's welded on! Removing the nuts from the positive side resulted in the bolt breaking right in half (with little force being applied) but the cable can be removed. Go figger.
Ah well, I'll watch a pro do it once.. and then hopefully I'll know.
Thanks,
Bob
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55315)
2017 Rogator...
2019 Ford Explorer AWD SUV (A55853)
2019 Ford Explorer...
Margaritaville Miniature Decorative Truck (A55853)
Margaritaville...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
