4300 Temp guage stays pegged on hot!!
   / 4300 Temp guage stays pegged on hot!! #1
robinhood560
South Mississippi
John Deere 4300 HST
My 1999 JD 4300 HST temp guage goes to hot after a short run up (30-45 sec.) I have replaced the sending unit and have checked connections to the cluster. What could be the problem??? Getting frustrated!! Please Help!!
Thanks,
   / 4300 Temp guage stays pegged on hot!! #2
Welcome to TBN:D
It could be a problem in the cluster, they had problems with them early on-mostly fogging up though and where replaced under warranty.
   / 4300 Temp guage stays pegged on hot!! #3
   / 4300 Temp guage stays pegged on hot!! #4
I had a plane that used to do that... The problem ended up being that once everything heated up there was a wire that short out. $10k later we figured it out.... Might want to check for any chaffed wires...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
UNUSED DIGGIT 6'5"-16 DRAWER, 4 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
John Deere Bale Spear (A55218)
John Deere Bale...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
