4300 SyncRev Problem
/ 4300 SyncRev Problem #1
jgbanshee
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
Every time I pull out in Forward with my JD 4300 the tractor jurks. When I select reverse and let out on the clutch, it moves fine with no jurks. I did adjust the linkage for the SyncRev lever down on the right hand side near the clutch. I adjusted it in favor of the forward position. Sometimes when I want to move forward the clutch seems not to be grabbing. If I tap the clutch pedal with my foot it usually will then grab and move the tractor. Reverse never has a problem so I am guessing (hoping) that the clutch is not the problem.
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
SARLO (A64557)
SARLO (A64557)
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
CAT 416B 24" Bucket (A68134)
CAT 416B 24"...
2015 CHEVROLET SILVERADO 2500HD (A67714)
2015 CHEVROLET...
