4300 range selector shaft
/ 4300 range selector shaft #1
mlip
Topsfield, MA
JD4300
Hello,
I'm new to JD, thinking of buying a used 4300 nearby. The range
selector lever has become disconnected from the shaft. The seller
says the shaft has "fallen" into the tranny case. Apparently an angry horse boarder forced the lever and broke the shaft purposely. Is there any way of
getting the shaft out without splitting the case? If the case needs
to be split, any idea what it should cost at the dealer? My local dealer says $1500....ouch. Thanks,
Mark
/ 4300 range selector shaft #2
mlip said:
Hello,
Mark
I do not see how you can retrieve it without splitting the tractor. I split my JD 4400 one time and you are talking major work. I split mine on a dirt floor sitting on wooden blocks. Can you get the seller to discount anything on the tractor to help pay the expense of the dealership doing the work ??
She's selling the machine for 6K, it has a 430 loader. Thats a really low price. It has 1400 hours, has been used in a big horse barn. Apart from the broken shaft its pretty dirty, has a broken plastic piece, but looks like its basically sound. Its a bit of a dice roll, but I'm going to take the plunge.....
/ 4300 range selector shaft #4
$6000 :eek: :eek: ,is it 4 wheel drive ??? I would go for it in a minute....you can find lots of parts on ebay if needed. Make sure you post some pictures of your discovered treasure....:D
yes its 4 wd. not a hydro tho. still a deal.
/ 4300 range selector shaft #6
You might want to run the serial number through Deere's Product Improvement search at Product Improvement Process : : John Deere. There were improvements available for the range selector on the 1998 and 1999 models. Also, be aware that the 1998 and 1999 mfwd models used a different front axle than the later models. They turned extremely tight but tended to scuff turf.
Jim, Thanks, thats a great suggestion, I'll check it out.
/ 4300 range selector shaft #8
I have the older style axle, but I do not use mine for lawn care. For $6000 I would buy it with either axle.
/ 4300 range selector shaft #9
Agreed. Sounds like a motivated seller to me.
/ 4300 range selector shaft #11
Yes, a $6K price sounds like the seller has already factored in the
selector shaft problem. (I hope it is stuck in LOW range.) I do not
know how many hours on the machine, but watch out for rust. A
tractor confined to horse barn work for 7+ years often suffers from
rust in its nooks and crannies, due to all the horse urine.
That said, grab it!
yup. Stuck in low range. It has 1400 hours. Its at the dealer now. He's preparing an estimate of what nees to be done. I'm sure it'll be at least 2K. Its still a great deal. Looking forward to getting it home.
John Deere 2755 Boom Mowing Tractor (A66285)
John Deere 2755...
John Deere 185 Hydro Riding Mower (A66285)
John Deere 185...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
6' 3Pt Bush Hog Mower (A66408)
6' 3Pt Bush Hog...
Rhino SE415A (A64126)
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
