4300 PTO Release
   / 4300 PTO Release #11
How about lifting the rototiller just enough to be able to rotate the PTO shaft just like you said you do with the brush hog?
   / 4300 PTO Release #12
I find with my 4300 that the PTO is either engaged and locked in gear with the drivetrain or disengaged and locked so it won't move/spin. In between these two positions there is a very small spot in the lever movement where you can actually turn the shaft. I have a small (4') offset rear mount bush hog that I made that needs to be sharpened after every few hours use (the blades are soft and I hit the odd rock beside the trail) This small sweet spot in the lever movement is the only way I can spin the blades by hand to get the grinder to them.
When I had the little "Bota" I could disengage the PTO and it would spin down freely, with the JD it stops abruptly when you try to dis-engage the PTO. A pain when using the brush hog or snow blower. The first time I blew snow I sheared the bolts when I pulled the PTO out of gear at operating RPM and the shaft STOPPED!
2020 Freightliner M2 106 Elgin Street Sweeper Truck (A55852)
2020 Freightliner...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
Skid Steer Attachment (A55787)
Skid Steer...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A55218)
2016 RAM 5500...
2015 JOHN DEERE 544K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2002 PITTS 102" X 35' LOWBOY TRAILER (A51406)
2002 PITTS 102" X...
