Tires 4300 or 4400 -R-1 tires
   / 4300 or 4400 -R-1 tires #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
Can any one tell me how tall the R-1 tires are? my R-4's are about 39.5". I found out the ground speed is alot different than what is labled on the tractor.
Thanks
DDT
   / 4300 or 4400 -R-1 tires #2
From the Deere Configuration web site:
Tire------------------Diameter--------Static Loaded Radius
15x19.5 (R4)-----------40.5"--------------17.9"
41x14.00-20 (R3)-------42"----------------18.6"
11.2-24 (R1 Standard)--43.6"--------------20.1"
12.4-24 (R1 Optional)---45.8"---------------21"
The static loaded radius should be used for calculating ground speed. Doing the math - R4 Circumference = 112.4". Standard R1 Circumference = 126.2". Given the same axle rotation speed should then result in the R1 tires giving about 10.9% higher ground speed.
Fugitive from the Cubicle Police
MJB
Thanks for the info. That is very helpful, I'm glad you did the math since I stink at that!
DDT
48in Farm Jack (A55852)
48in Farm Jack...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2022 Bogballe M45W (A53317)
2022 Bogballe M45W...
2008 Freightliner B2 School Bus (A55852)
2008 Freightliner...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
