Tires 4300 or 4400 -R-1 tires
   / 4300 or 4400 -R-1 tires #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
Can any one tell me how tall the R-1 tires are? my R-4's are about 39.5". I found out the ground speed is alot different than what is labled on the tractor.
DDT
   / 4300 or 4400 -R-1 tires #2
From the Deere Configuration web site:
Tire------------------Diameter--------Static Loaded Radius
15x19.5 (R4)-----------40.5"--------------17.9"
41x14.00-20 (R3)-------42"----------------18.6"
11.2-24 (R1 Standard)--43.6"--------------20.1"
12.4-24 (R1 Optional)---45.8"---------------21"
The static loaded radius should be used for calculating ground speed. Doing the math - R4 Circumference = 112.4". Standard R1 Circumference = 126.2". Given the same axle rotation speed should then result in the R1 tires giving about 10.9% higher ground speed.
Fugitive from the Cubicle Police
MJB
Thanks for the info. That is very helpful, I'm glad you did the math since I stink at that!
DDT
UNUSED 1RANCH 1RIG-13' 14' BI-PARTING IRON GATE (A57193)
UNUSED 1RANCH...
2019 Autocar ACX Xpeditor T/A EZ-Pack 40 Yard Front Loader Garbage Truck (A55852)
2019 Autocar ACX...
Year: 2018 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 87,823 (A56859)
Year: 2018 Make...
UNUSED FUTURE PAIR OF 7" MINI RUBBER TRACKS (A57193)
UNUSED FUTURE PAIR...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
UNUSED WOLVERINE BSH-12-75D BALE SQUEEZE (A57193)
UNUSED WOLVERINE...
