4300 front wheel bearings
/ 4300 front wheel bearings #1
tim_s
Canton, TX
JD 2555
I need to rant a little here. My 4300 (2wd) has lost another front inner wheel bearing. Different side than last time, but the same bearing. As aggravating as this is, bearings do go bad. The problem comes in at the part dept. My wife was mowing, calls me says the front wheel is locked up. I've seen this before, no big deal, I call the dealer (Ag-power in Terrell, TX). I tell them I need the inner and the outer bearing. The parts guy says yeah no problem, we got 'em. I send the wife to get them. I get home, pull the tractor onto the driveway behind my truck and take the hub all apart. Then I look at the new bearing. Yup, two outer bearings. Crap. Now I'm really stuck. The tractor is up on the loader with only one front wheel. I can't get my truck out. I can't put the old bearing back in (it was in little pieces). All because the parts guy can't do what I asked and give me the inner and outer bearings. So then I have to drag the tractor on the loader down the driveway to get room to get my truck out, and the wife is jumping up and down about the scratches on the concrete. And meanwhile the pasture gets taller.
Sorry to carry on, but I needed to vent.
Tim S.
/ 4300 front wheel bearings #2
I know what you mean there. I called The JD parts guy, asking for 2 bushings for the tail wheel on a JD 616 rotary cutter. Yep, the computer says we have 2 in stock. I tell him to put my name on them and the wife will stop by after work. She stops and the parts guy says they don't have em. We ordered them and they'll be here tomorrow.
What was that old song about computers don't lie? /forums/images/graemlins/shocked.gif
At least it wasn't as bad as your deal.
24 Gauge R Panels (A65640)
24 Gauge R Panels...
213212 (A64277)
213212 (A64277)
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A65579)
2014 Jeep Wrangler...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
100 Gallon Galvanized Water Tank (A65579)
100 Gallon...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
