430 loader fix
/ 430 loader fix #1
yellowsocks93
Veteran Member
MN
John Deere 990 MFWD and a few others
Today I finally got the 430 loader to properly work with my 990. I had to loosen the bolts that hold on the rear masts and the 4 bolts in front of the loader. Then you install the loader with the hardware loose and when the loader is on properly then you tighten it. Works like a charm now and I no longer have to jack the front of the loader up to get the latch plate over the weight bracket.
/ 430 loader fix #2
I replied to your post on 12/3...although it seems extreme you need to loosen the hardware to get your loader installed I am happy that works for you!
/ 430 loader fix
Ah I must have not saw that sorry. But I went to work and had the service manager pull up DTAC its the techincal info for dealers.
Pat's QH and hydraulic top-link.
Pat's QH and...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
KL480 Ventrac tiller
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
