MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,050
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I just came across my PDF copy of the drive pump manual. Provided they are still using the same pump, which seems likely, the specs call for +/-15 degrees max rotation for the control shaft that is operated by the treadle.
The control shaft operates an internal swashplate that controls direction and flow of the pump's output. The manual states that the control shaft has no internal spring or other centering device, and that internal forces may move the control in either direction, therefore the control system must hold the swashplate control shaft at the desired angle.
I read that to say that a sloppy or loose treadle control could result in erratic operation.
Does he have the hydraulically controlled treadle? If so, how can he check that as opposed to the cable controlled treadle that we have?
