425, 1845, PT Day
   / 425, 1845, PT Day #1
Charlie_Iliff
Arnold, MD
Power Trac PT1845, John Deere 2240, John Deere 950, John Deere 755, Jacobsen Turf Cat II
It was a great Power Trac Day. Hans (Bubenberg) Luginbuhl just left my place after seven hours of work and testing, and a pleasant supper. He brought down his PT425, two Kunz Acrease wing mowers, the grapple bucket, forks and brush hog, all on a 20' trailer.
First, we had to do some tire repair, since some necessary evasion on the way down had resulted in load shift and a flat on the PT. One new stem, some glue and some Slime did a temporary fix that only needed air one more time during the day. I mowed a pasture, towing the two wing mowers. I was cutting about a 14' swath. It wouldn't be too hard to convince me that I need those. Hans has welded a PT
attachment plate to each mower, so he quickly loads and unloads them, without any effort at all. While I was mowing, Hans demonstrated the grapple bucket by moving a big pile of brush and old wire fence, not to mention a 30' by 6-8" thick tree.
We then switched mine to the Lackender hoe, and I demo'ed digging with the curl on my new button circuit. Hans then played with the hoe, tested the machine on some slopes, and we talked through possibilities for modification of the 425 to a
similar circuit switch configuration. The system works well, but may ultimately need yet another circuit, for a movable thumb on a grapple. It also needs to be a lot less expensive, and some thought has to be devoted to exactly where to mount it on the PT425. The valve I used barely fit behind the lift cylinder on the right, and there are signs of contact to one of the fittings.
But, it worked, and Hans was able to further arrange the pile of brush, using the hoe and thumb as a grapple, and only one hand to control it. He will report in due course, and I will try to post a bit more technical detail within the next few days, with a picture or two. It isn't the only answer to the lever-by-knee problem, but it works well.
It was great to meet face-to-face a man who has been a friend on TBN and an influence on my buying the PT in the first place. We are planning a trip to Tazewell together to see new toys, er, equipment, and to see if we can nudge them
into a couple of fixes and improvements.
   / 425, 1845, PT Day #2
Great report! Wish I could have been there, if anything, just to meet you guys. /w3tcompact/icons/smile.gif
   / 425, 1845, PT Day #3
Charlie and Hans,
Thanks for all your hard work on this.
PJ
   / 425, 1845, PT Day
<font color=red>"Great Report"</font color=red>
It was a great day, but as I read back through my post, it certainly was not a great report. For instance, I completely forgot to mention about 60 post holes I drilled around the same field we were testing in, while Hans was running back and forth with posts from a pile a couple of hundred yards away. Just as I drilled the last hole, he dropped the last post off his grapple bucket, right next to me. Maybe it slipped my mind because the whole thing was so easy with two PTs. /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif It took less than an hour, even with a stop for a diet coke delivered by my brother who had taken a break because he had just trashed a new sawmill blade when it encountered a ceramic insulator in the middle of a 40" poplar log.
   / 425, 1845, PT Day #5
/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
Two PTs going at it. Man, sounds like a little bit of heaven! /w3tcompact/icons/smile.gif
   / 425, 1845, PT Day #6
Sounds like a great way to get work done around your place. /w3tcompact/icons/wink.gif Can I host the next one? /w3tcompact/icons/grin.gif/w3tcompact/icons/laugh.gif
-Scott
BTW, ordered a rake for mine last week. Sean mentioned that they would be sending out a mailer to 4xx owners detailing the new attachments soon.
   / 425, 1845, PT Day
<font color=red>Can I host the next one?</font color=red>
Careful what you wish for. We survived two PTs on the same patch of ground, but three...?
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
New/Unused CFG Industrial H15R Mini Excavator (A54865)
New/Unused CFG...
2005 Ford Explorer 4X4 SUV (A55758)
2005 Ford Explorer...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
