422 blew up part II
/ 422 blew up part II #1
scarg
Bronze Member
Upstate NY
PT 422 Mod to kawi 29HP FD791
I have been researching small engines for the past few weeks and settled on a liquid cooled digital fuel injected 29HP Kawasaki - Kawpowr.com - 4 Cycle Engines
I will have to relocate the radiator and possibly the air cleaner to make it fit but other than that it should eliminate all concerns about the 422 being under powered and all of the cold starting issues.
The torque curve is very flat and above 40 in lbs at all rpms above 2000. The robin 22hp was only 32 or so.
If anyone is interested i can make a "kit" for the 422 with drawings etc.... otherwise i will make it without drawings to move things along faster.
/ 422 blew up part II #2
I hope it goes well. Looking forward to your posts on the project, with photos, of course. :)
/ 422 blew up part II #3
It looks like a nice engine.
I notice that Scag uses them in their zero turn radius mowers, and that they suggest a maximum slope limit of 15 degrees. You might want to check with Kawasaki to make sure that your slopes aren't steeper than the oil pump can handle.
How steep are your slopes, by the way?
All the best,
Peter
/ 422 blew up part II #4
I would love to upgrade my engine for the extra wheel motor torque, as I assume this will help. Will your kit work on the PT 422s that have pumps behind and in front of the engine? I understand the Robin engine requires a crankshaft modification for this.
/ 422 blew up part II #5
I can't ask you to make a kit--however pictures are a must.:p If this engine will fit in a 422, it should fit in a 2422, and also in the 425 series. With all the interest in the "stronger" wheel motors, a higher-horsepower LIQUID-COOLED engine would seem to be very high on the list of upgrades. These machines don't wear out; all the components can be replaced; the "new model" is just as "pretty" (it's a tractor) as the "old model" so that is no reason to buy a new one. Upgrades make sense, maybe you should make a kit.:D :D
Bill
/ 422 blew up part II #6
Very interesting, you may end up with a new breed of super PT. I agree pictures would be great. :p
Ponytug,
Thanks for your reply. Generally my slopes are much less than 15º and nearly flat. However I do have some pretty steep areas that i could not climb with the 422. I am not sure of the slope on these but they are roughly 30º if i was to take an eye ball guess.
The 15º limit on the Scag appears to be related to safety for the operator and not related to the engine.
The new 2007 Model 429 PT's engine uses a pressurized positive displacement oil pump which takes in the oil very close to the bottom (less than 1/4" ?")of the crankcase bottom with a flat large surface area intake nozzle. Judging by he position of this i would expect that you would be safe at well over 30º slope. Even if the engine was almost on it's side (~70º from operation position) it appears as though it would still be able to pump the same as if it was in normal position since the positive displacement pump has no choice but to output the same amount of oil in any orientation (provided it is still getting oil!)
If i am missing something please someone let me know...
Any and all input is greatly appreciated.
BR,
Steve
Not sure- I have not seen one of those. However anything is possible and perhaps kawasaki offer this option. I have note seen it yet but it is possible.
Steve
oops - was in response to ...
Bobrip -
I would love to upgrade my engine for the extra wheel motor torque, as I assume this will help. Will your kit work on the PT 422s that have pumps behind and in front of the engine? I understand the Robin engine requires a crankshaft modification for this.....
Steve
/ 422 blew up part II #10
1st- If your land is flat, then it is a non-issue. If it isn't, just ask Kawasaki; I am sure that they will tell you. I know the Robins/Subaru numbers, because I called and checked, when I was considering a 425. According to them, 20 degrees is their maximum sustained angle, and 25 degrees only for short time periods.
Generally, the limit has to do with both where the pickup is, and where the rest of the oil is. If the pickup is covered, but the oil is being splashed by the crankshaft, you get foamy oil, oil plastered on the side of the crankcase and not alot of oil being pumped around. Race car mechanics, rally drivers, and aircraft engineers tend to worry about these things, but most of the rest of us never encounter a problem where it rears its ugly head.
There are lots of solutions, dry sumps, dual oil pumps, swinging oil pickups, but beyond the scope of what you need, or probably want to think about.
I just wanted to make sure that the engine would do what you need it to do.
All the best,
Peter
scarg said:
Ponytug,
Thanks for your reply. Generally my slopes are much less than 15コ and nearly flat. However I do have some pretty steep areas that i could not climb with the 422. I am not sure of the slope on these but they are roughly 30コ if i was to take an eye ball guess.
The 15コ limit on the Scag appears to be related to safety for the operator and not related to the engine.
The new 2007 Model 429 PT's engine uses a pressurized positive displacement oil pump which takes in the oil very close to the bottom (less than 1/4" ?")of the crankcase bottom with a flat large surface area intake nozzle. Judging by he position of this i would expect that you would be safe at well over 30コ slope. Even if the engine was almost on it's side (~70コ from operation position) it appears as though it would still be able to pump the same as if it was in normal position since the positive displacement pump has no choice but to output the same amount of oil in any orientation (provided it is still getting oil!)
BR,
Steve
/ 422 blew up part II #11
So, how does the deutz deal with slopes? I did not notice anything special about the pickups unless PT is modifying them?
/ 422 blew up part II #12
No clue. Since the 1850s run at 45 degrees, the engine clearly works. The engine does have a relatively deep oil pan, which would favor sloped use.
All the best,
Peter
Ponytug,
The manual for the 29HP states 25コ continuous is okay. Anything steeper must be not continous. (they don't state any more defined than that)
BR,
Steve
/ 422 blew up part II #14
scarg said:
Ponytug,
BR,
Steve
I think the Kohler Commands have that same 25 degree spec. I can't see ever being on a steeper slope than that for very long. I certainly wouldn't want to be working a 422/425 on a steeper sideslope. I can see (for my use) a brief intermittent steeper slope, when going straight down off a bank or something.
/ 422 blew up part II #15
Dear Steve,
For what you need, that sounds great. As others have mentioned, I wouldn't want to be on slopes that steep with a 425, or a 429. :) YMMV
All the best,
Peter
scarg said:
Ponytug,
BR,
Steve
/ 422 blew up part II #16
Another thing to remember is the slope rating is for a full sump. If the engine oil is down some, the slope rating is likely to be compromised.
Just one more reason to check the oil prior to each use.
/ 422 blew up part II #17
Does the transmission sump have a slope limit? It's probably different on some pumps than others since the pump intakes are at different heights.
500BBL WHEELED FRAC TANK (A60736)
500BBL WHEELED...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
DOOSAN 7K FORKLIFT GS35-5 (A60736)
DOOSAN 7K FORKLIFT...
2021 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2021 KENWORTH T680...
2016 FORD F-550 SUPER DUTY (A60736)
2016 FORD F-550...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
