4210 MFWD LEFT AXLE LEAK
   / 4210 MFWD LEFT AXLE LEAK #1
brianpoff
Hey folks,
I was just wondering if anyone could enlighten me on how involved it is to change the front axle seal. I just went into the garage and noticed a puddle of oil under the tractor that is coming from the front wheel. Has anyone ever done this, had this problem, etc?
Many thanks,
Brian
   / 4210 MFWD LEFT AXLE LEAK #2
You might want to confirm that it is actually the axle seal and not the knuckle seal. The knuckle seal (M136687 on my 4410) seals the rotating-about-kingpin axis knuckle housing to the MFWD axle housing. These tend to leak and if they leak on the outboard side the fluid will run down the inside of the tire. This may give the appearance of an axle seal leak which obviously seals the axle.
My tractor leaked here when I bought it (used '03 4410 in '07) and I had replacement seals on hand that came with the tractor. The repair procedure (dealer let me read tech manual) was straightforward. It basically involved removing front axle/hub assembly (easy via large bolted flange on housing), the tie rod and then removing a series of snap rings, clips, shims, bearings and washers to disassemble the knuckle. None of it looked really difficult and armed with a parts drawing one could reassemble w/o issue.
If you really only need the axle seal, that's real easy and would only require removal of front axle at the hub flange and disassembly to that seal includes a couple bearings, a spacer and a snap ring.
The beauty of it was I didn't have to replace my knuckle seals. I simply removed the front wheels, cleaned all of the grass, mud, etc from this area and viola, no more leak (6 months ago). When I checked the service history on my tractor, I found that these had been replaced before under warranty and probably for the same reason - crap jammed into the knuckle seal area.
Thanks. It is the outer seal. I am going to unbolt the assembly and see if I can get it apart. I found a service manual, but hate to shell out 200 bucks. OUCH!
Wish me luck.
   / 4210 MFWD LEFT AXLE LEAK #4
Last I checked the technical manual should be $75 on CD and $150 in book from JDParts.com
   / 4210 MFWD LEFT AXLE LEAK #5
ive done front seals on my 4310, but a suggestion clean around the flange and seal and take a piece of heavy twine and run around the seal to loosen any thing that may be holding the seal open fill the axel and drive it a while to see if whatever was holding the seal open was dislodged.
if it still leaks then replacing it may be called for.
the first seal i replaced i couldnt see any damage to it, they are prone to string twigs and othe debrie opening a gap.
and its not a dificult job you may want a fair sized 3 prong gear puller.
Thanks. Will do.
Informational Lot - Financing (A55302)
Informational Lot...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
MISC TIRES (A54756)
MISC TIRES (A54756)
UNUSED GRASSROOTS IMPLEMENT 6' LAND PLANE (A54756)
UNUSED GRASSROOTS...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
