4200 rear axle seal
   / 4200 rear axle seal #12
I have a 4200 JD as well I have removed rops all 8 bolts and disconnected the brake linkage but I am having trouble removing the housing feels like it is getting hung up somewhere tho....if it not supported could that be the issue or could I be missing something else to remove....
   / 4200 rear axle seal #14
im replacing the right hand side I think the brake lever on the housing is where its getting hung up....I cant tell if its a star hex or square or is it a pin I need to drive out to remove the lever?
   / 4200 rear axle seal #15
A steel roll pin holds the brake lever on.
   / 4200 rear axle seal #18
I realize this is an older thread, but I plan on replacing a leaky rear axle seal on a 4400 in the near future. Can someone tell me if I need a hydraulic press to remove the axle once I have the housing off the tractor? I just want to be prepared. Thanks in advance!
   / 4200 rear axle seal #19
There are tutorials on TBN (by the way :welcome: ) as well as I'd suggest getting the tech manual that covers your tractor model would be worth the investment. Torque values and removal procedures are outlined.
Can do one side at a time, although one other thread removed more than necessary, according to the tech manual.
http://www.tractorbynet.com/forums/parts-repairs/84836-4310-jd-rear-axle-seal.html
Also, the tech manual says (for right side):
Need to remove the parts in your way to get at the 8 cap screws holding the axle (final drive) housing to the transmission housing.
That would be the 3 pt hitch arm, wheel, brake spring, brake rod, park brake, ROPS bolts, and gently pry the final drive housing away.
Will need good blocking under the tractor and maybe a way to support the weight of the ROPS.
Might be a real good time to get the tech (service) manual if you don't have one already. Worth it as there are pics and detailed steps.
Here is a schematic from jdparts.com that may help you visualize the task... should be doable.
Items 12 and 13 are the cap screws that hold housing #6 to the tranny. That final drive weighs about 75 lbs according to the book so some support is advised when removing the 8 cap screws.
Here is schematic for 4200 right side.
   / 4200 rear axle seal #20
Thanks for the reply. I actually did purchase the factory service manual(for a small fortune) a few years ago. This manual says the axle needs to be pressed out, however I've seen a few threads on here(including the one you linked to) that lead me to believe this is not necessary. This is what I am trying to clarify. I just want to have all tools necessary before I start the job...
Thanks in advance to anyone who can help me with this!!
2007 Chevrolet Silverado Service Truck, VIN # 1GBHC24K77E577417 (A57453)
2007 Chevrolet...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
TANK MANIFOLD (A58214)
2357 (A58376)
2357 (A58376)
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58216)
8 TOOTHED BUCKET...
